Discuss Retrofit pipe clips in the DIY Plumbing Forum area at PlumbersForums.net
Looking at retrofitting some pipe clips to existing pipe runs . Unfortunately when the pipes were install originally there is literally minimal space between them (not by me- probably the original pipe runs), so a pipe clip with the screw space in the centre won’t work and can’t lift the pipes to put in centre screw pipe clips. Currently they are old style packed out with foam and matting through the joists.
spotted these.. Fliptop Wrap Over Pipe Clip with End Fixing - 22mm - https://www.bes.co.uk/fliptop-wrap-over-pipe-clip-with-end-fixing-22mm-9617/?ref=gs&gclid=EAIaIQobChMI95qmqs607gIVnoBQBh3fmQIgEAQYASABEgL-cPD_BwE
which look they would work - minimal fitting on one side and screw placing where I could attach it.. anyone used these?
Reply to Retrofit pipe clips in the DIY Plumbing Forum area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
