Discuss Replacing motorised valve steps in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Folks,
Please advise as i wish to change a motorised valve connected to a heat only gas boiler:
Turn off the boiler
Turn off the mains water
Find a draining point and drain system
Replace motorised valve
Make sure draining point is closed.
Turn on mains.
Turn on boiler.
Bleed the radiators.
Job done?
Donā€™t know if these pics are of any use to you.
How to take apart a valve, I did for someone a while ago.
Complete valve
Cover removed
Two screws you need to remove
Pull head off
Body
Reply to Replacing motorised valve steps in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
