Discuss Replacing heated towel rail on combi system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes, I have already got one of those, hence my request for an estimate for STAINLESS STEEL. Screwfix have a Reina Curved Ladder Towel Radiator 1200 x 500mm Stainless Steel (28769) for £316.92. But I need a 600mm width. My guess is that I am looking at spending £450 including labour and VAT, but then I am not a plumber, hence my question on here. I have asked 3 local plumbing firms for an estimate. Two said they will get back to me but haven't, one didn't respond. I would have thought that this is a straightforward job to estimate and carry out.
It's the wrong time of year for many people to be interested in a job that a typical customer will want to pay £30 for but will disrupt a whole morning.
Can you combine it with another job, such as your annual service, to dilute the 'nusiance factor'?
The boiler service isn't due until next April, I haven't got any other plumbing jobs that need doing. Screwfix does a Curved Ladder Towel Radiator 1200 x 600mm Stainless Steel for £350 - that's the size I need. With new valves and rust inhibitor, plus labour and VAT, my estimate is £500. £30 is ridiculous!
The bathroom walls have got plywood sheets on wooden battens on brick walls, the top half is skimmed over with plaster, the bottom half below a dado rail has got Marbrex waterproof panels over the plywood. The copper pipes protrude through the Marbrex and connect to the valves at the bottom of the towel rail.
Reply to Replacing heated towel rail on combi system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My towel rail is not electric but separate to central heating and has been working consistently but since the 2 port valve was replaced on Monday...
Hi there, Can I simply undo the screws on this heater towel rail, make sure it's off and prop it up while I paint the wall behind it? I saw...
Hi I’ve got a blockage somewhere that’s preventing the GCH bathroom towel rail from heating. Plumber has offered to try and resolve it at...
Deleted member 120897
I have a caravan with a brand new heating system.The Valliant combi boiler is working fine but one radiator and one towel rail are stone cold.I...
