Discuss Replacing heated towel rail on combi system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have got a Worcester Bosch combi boiler heating system with a MagnaClean filter. The heated towel rail in the bathroom is white and rusting, so I plan to replace it with a chrome rail to reduce the likelihood of future rusting. Am I right in thinking that when I disconnect the existing towel rail that a lot of the water in the system will drain out even with the valve which controls the supply to the boiler turned off? One of the radiator valves is faulty, it won't turn off, so I need to fit a pair of new valves on the new radiator, hence the question about water draining out.
In my experience of towel rads of any finish, the rubber washers they supply are absolute rubbish, they always leak and rust. So
do not use them. PTFE wrapped correctly is the only sound way
inc. valve leaders the bleeds on the top and the blank.
centralheatking
What am I likey to be charged to have the existing towel rail (600mm by 1120mm curved) which is rusting replaced by a curved stainless steel towel rail plus a pair of new valves.
[automerge]1567973381[/automerge]
Reply to Replacing heated towel rail on combi system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My towel rail is not electric but separate to central heating and has been working consistently but since the 2 port valve was replaced on Monday...
Hi there, Can I simply undo the screws on this heater towel rail, make sure it's off and prop it up while I paint the wall behind it? I saw...
Hi I’ve got a blockage somewhere that’s preventing the GCH bathroom towel rail from heating. Plumber has offered to try and resolve it at...
Deleted member 120897
I have a caravan with a brand new heating system.The Valliant combi boiler is working fine but one radiator and one towel rail are stone cold.I...
