Discuss Replace control unit with Nest in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
N
New Used
Hello,
I have a LOGIC a combo Esp1 35 boiler and CM707 control unit.
I want to install Nest - however from looking online the two inputs are 240v from the boiler (cables are thick).
Were it not for the voltage it looks a simple job. How can I do this myself ? Thanks
Reply to Replace control unit with Nest in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
