Currently reading:
Replace 2-wire Honeywell CM707 zone stat
Discuss Replace 2-wire Honeywell CM707 zone stat in the Plumbing Zone area at PlumbersForums.net
T
Tractorman
Hello. I have a two-zone heating set up, with each zone controlled by a 2-port zone valve (Honeywell V4043H by the looks of it), and each zone has a two-wire HoneywellCM707.
I would like to replace the CM707 in the master bedroom (for a mechanical stat that doesn;t click). In terms of compatibility, is this suitable: DRAYTON RTS8 COMBISTAT
The voltage across the live and return wires feeding the CM707 is high 240v AC. I don't know about the current amps - as I am waiting for a multimeter to measure AC (amps).
Would appreciate any thoughts. Thank you!
Zone valves: Honeywell V4043H
Boiler: Pottertron Assure Combi
Problem is these days most of them click if it’s mechanical the only ones that don’t are digital eg buttons
There is regular mechanical clicking and there is whatever goes on inside the Honeywell CM707! It's as loud as hell.
I've put the RTS8 on, 2-wire install.
Reply to Replace 2-wire Honeywell CM707 zone stat in the Plumbing Zone area at PlumbersForums.net
