Discuss Removing unused stack pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Just wondering if the 4" stack pipe shown on the attached photo can be removed and capped at ground level?
The bathroom was originally upstairs and now relocated to downstairs with the waste plumbed directly into underground pipework.
Not sure whether this is still required for the underground system.
It will depend on the existing plumbing.
If it's a main vent - then no - , but you could reduce it down to 50mm instead of 100mm.
Maybe just cut it off just above ground level and put a cap on it..
If it doesn't affect the rest of the drainage for a certain period of time, then permanently cap it off..
If it does, run a 50mm vent up the side of the building
Would a stub stack be ok for this.
I don't have any drainage from upstairs, mainly wanting to tidy up the plumbing, along with this there's 4 water waste pipes running along the wall all just going to rainwater gully
Would need to be 3m high plus 2m away from a window minimum
Reply to Removing unused stack pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
