R
rogdee
Hi, new to this forum. I have a leak from a plastic push fit elbow. It is grey and marked HBP 15, my research so far says this is an old style hepworth fitting? It doesn't appear to be easily dismountable, but is there an easy way. It is on my central heating system connecting the main pipe to a radiator. (Plastic pipe in concrete - HBP 15 fitting - copper pipe to rad valve.) I have had to chisel out concrete to get at the joint and a short length of pipe. Because of the concrete I guess, the plastic pipe is a bit scratched and marked but not seriously damaged. Will I still be able to make good connections with this pipe using new push fit connectors or would brass compression be a better option. I think this fitting has been installed for approx 15/20 years, we have lived here 11 years and had been altered quite a while before. The leak is actually caused because it seems that whoever fitted the solid wood laminate flooring did not leave any real clearance around the rad pipe and expansion of the wood over the years i guess has semi-squashed the copper pipe coming out of the top side of the elbow. Sorry if I have rambled on a bit but any help or advice would be greatly appreciated.
