Discuss Removing Durgo valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PhoenixServices
hi guys. Bit of a basic question.
I'm altering kitchen pipework at the minute and In one corner is a stub stack that just had a washing machine going into it before. This will be redundant can I just cap the stack in the floor removing the Durgo without it causing any issues( house has a vented stack through roof elsewhere)
It probably will not make any difference. But try removing the Durgo and temp seal it for a week first just to make sure it does not create a problem elsewhere and cause a syphon effect to other amenities. A plastic bag and rubber band etc will do. If everthing else still seems to work ok and no empty traps & nasty smells occur then you are good to permanently remove and seal it off.
Reactions: rpm
The reason has been removed it served a washing machine upstand only. Capped off today will see how it goes over the next couple of days before the kitchen goes in but was fine all day today.
Reply to Removing Durgo valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
