Discuss Remote Control Gas Fires in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
Foodface
Hi all just wondered what peoples experiences and or thoughts are on remote control fires. I've serviced a fair few of them now and find them quite temperamental. I did one two months back and it took me nearly two hours to do cos I couldn't get it to fire up again after, the appliance had never been serviced in five years and was filthy. Fired up fine before the service but after it was being temperamental.
Customer has been in touch saying it won't work the same and they are not using me again for further work, offered em a refund but to be honest I didn't do anything different to any other gas fire service.
Has anyone else had problems of this kind cos my pride has taken a bit of a knock on this one.
Foodface
Not worked on that many thankfully, custard sounds a bit of a pain if they didn't give you a chance to put it right! Never mind eh? ........... :grouphug:
Not sure what else I could have done anyway, asides strip and clean it again. Wouldn't mind but I heavily discounted the fire service anyway. Gave it em for £35.00 with a central heating flush for £99.99. Suppose it isn't that much to refund though.
Had one where the remote had stopped working while it was on
That was a weird emergency call out because fire was embeded and the only control was the remote just seemed dangerous to me, the only way to stop it was isolate the gas and hope the thermocouple held
they or a least this one seemed a bad idea
whats wrong with your one, did you change the burner pressure or anything
sorry did you just say you did a power flush for £99
Nah was a chemical flush x400 and then x100 after a hot flush. Never changed anything, just stripped cleaned and tested for performance n safety. I have thought that about the remote only ones, they offer no alternative means of lighting or turning off the appliance.
Probably little else other than passify them .. not worth the time wasted and they'd probably not pass on your details anyhoo's by sounds of it?
Try and forget it and move on foodface ... :)
oxydepletion device sometimes works too well with the glass fronted fires, should only set them on cool at start not hot as instructions state with one make i service, forgot the name tho.
Reply to Remote Control Gas Fires in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
