Currently reading:
RCD trips when tank stat turned own
Discuss RCD trips when tank stat turned own in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
klunk
My heating system is a myson apollo 30b with a 3 way valve etc.
The other day wife said was a popping noise coming from kitchen where the programmer and boiler is , on investigation i have found when you turn down the tank stat which is a drayton hts 3 it when it gets below the temp and you can here the click in stat it causes the fault, Sometimes tripping the main rcd in the house,
I changed the 3 way valve,programmer and tank stat about 18 months ago and have had no problems up to now
I also looked at the fuse in the spur for the heating which is a 13amp should this not be a 5amp?
Extremely helpful. Take the advice given.
For your own safety.
Thread closed.
Reply to RCD trips when tank stat turned own in the Plumbing Jobs | The Job-board area at PlumbersForums.net
