Yes it's intermittent it might work for a few hours and then lock out or maybe even a few days. We had the engineer out and he changed the solenoids but this didn't fix itBoth burners lockout after trying to ignite on first attempt?
Discuss Rayburn 499k heating not firing in the Central Heating Forum area at PlumbersForums.net
Yes but it's intermittent it might work for a few hours or even daysBoth burners lockout after trying to ignite on first attempt?
We have just had it serviced by a rayburn engineer and yes it was fine when he was here. Just wondered if there was anything else we could try what about changing the control box?Changing all the solenoids is a bit OTT, one may have been at fault but highly unlikely all of them. Intermittent faults often prove to be the most frustrating as more often than not the cooker plays ball while the engineer is attending.
If you go on the Aga/Rayburn website you can book an engineer in for a visit. Unfortunately this is not something I can say for sure is the problem over the phone.
I agree, but I'm at a loss as what to try next, any suggestions thanksYou say it's both burners that lockout? Chucking parts at a problem in the hope to fix it is not a good idea and can be costly, especially if you're doing it for two burners at once.
The fault sequence is loss of flame signal according to the manual. Steady red for 10 secs 1 short flash 4 long flashes then repeated, so we just press the reset button and it fires up. It's more likely to happen if the back door or a window is open and there is a draughtI agree, but I'm at a loss as what to try next, any suggestions thanks
Yes try that and be careful doing it and when the engineer returns see if he will service the burners.
Once you've broke the grout try removing the panel yourself, undo the screws ad release. If its removable you're laughing.
I really like these appliances, although I personally don't have too much experience with them, I know pressure jet burners and would be more than prepared to take my time getting to the bottom of issues. Unfortunately a lot of engineers don't like them and most who know what they're doing are close to, if not already at retirement age, so if the engineer gets you out of trouble then keep him around.
Yes it's on both burnersBoth burners clearly light. You say it locks out on loss of flame signal, is that both burners?
Thanks for your help. I will get the engineer back out to check what you mentioned.Here is a copy of the report from the service. Does it look OK to you
Reply to Rayburn 499k heating not firing in the Central Heating Forum area at PlumbersForums.net
