Discuss Range rating for a Grant Vortex Pro External Condensing Combi Oil Boiler 26kW in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My new Grant Vortex Pro External Condensing Combi Oil Boiler belches vast amonts of steam condensate fromthe exhaust flue. It clearly needs its maximum allowed rating adjusting downwards. Is it possible to do this please? If so, where is the adjustment?
You'll not touch it. It's doing what it should be doing.
You know what condensing means don't you?
It is quite normal for condensing boilers to produce billowing plumes. Way in excess of their non condensing counterparts. You certainly arent the first homeowner to be startled by the difference.
You should not adjust anything.
Indeed I do. The boiler can only achieve max efficiency by leaving the condensate within the heat exchanger to deliver its latent heat to the system, not the air outside. The
rating is too high for the system load.
your a special kind of prat aren't you ,leave the boiler alone and go back to your crayons
Reply to Range rating for a Grant Vortex Pro External Condensing Combi Oil Boiler 26kW in the Plumbing Jobs | The Job-board area at PlumbersForums.net
