Discuss Rads coming on when hot water is on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
ive just changed the 2 port on the heating side as I thought it was letting by as all rads started to get hot when only water on demand.
Fired up boiler on demand for water once changed 2 port, flow pipe to rads underneath 2 port stone cold but rads still warming up at a slow rate.
Checked bypass and it's fine. I put 10 replacement rads a couple months ago and when heating on demand all heat up nicely.
Heat only boiler, unvented cylinder.
**update**
I've just noticed it's the return pipes from rads heating up when hot water is on
Any suggestions? Blockage somewhere?
Is the pipework following the three tee rule?
Not sure as return paths are concealed. "Apparently" this only started happening when I changed the rads! Pffft
I wonder if the old rads had unidirectional TRV's (if they had TRV's) which prevented this reverse circulation? Now you have new rads in with bi-directional valves the problem has been able to show itself?
Good point!! I'm gonna try pop back today so I'll see if I can get a butchers at the return path and order of the heating, water and bypass.
So the order after the pump is:
DHW, Heating, Bypass
Should be:
Bypass, DHW, Heating. Same order on return. But return pipework is concealed.
That right?
Yes, KingDoey has it right. The original installer didn't follow the 3 tee rule. DHW last connection before boiler. This diagram shows you what happens when you tee in the DHW return before the Heating circuit. I reckon that's what you've got going on and it has only shown as a problem with your new bi-directional TRV's.
http://www.hertsboilers.co.uk/tech/backflow.jpg
Reply to Rads coming on when hot water is on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
