  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Radiators won't turn off in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Ant5
    Ant5 Guest
    Grateful if someone could help with this (probably very basic) problem. I have two of my radiators turned to 'off' yet when the heating is on, they both pump out heat full blast. Other radiators in the house stay off when turned to this setting- any ideas why this might be happening?
  2. PlumbBobBob
    PlumbBobBob Guest
    are you turning the rads off by using the trvs?
  3. Ant5
    Ant5 Guest
    Sorry, not sure what trvs is? I'm using the valve on the side of the radiator.
  4. PlumbBobBob
    PlumbBobBob Guest
    trv=thermostatic radiator valve (big white lump on rad valve). are you turning feed or return off? sounds like valve is not turned off enough and still letting by.
  5. Ant5
    Ant5 Guest
    Yes, I am using the trv- on both radiators, they're turned as far as possible (tightly too) onto the 'off' position. I have other radiators in the house on this position and they remain off.
  6. Simon F
    Simon F Trusted Plumber GSR
    sounds like the head of the valve is bust, to test take the head of, is there any resistance and movement on the rod inside when turned. easy test swap for one of the trv heads that you know works.
  7. stevetheplumber
    stevetheplumber Plumber GSR
    you shouldnt realy be turning of rads using the trvs your room stat is the thing to use
  8. Howsie
    Howsie Plumber
    Why not? This is what they are for.
  9. Unregistered
    Unregistered Guest
    Just wondered if you ever got to the root of the problem on this one? I have the exact same problem on two radiators in my house now and not sure what to do
  10. Matchless.plumb
    Matchless.plumb Trusted Plumber Top Contributor!!
    As mentioned previously either rod is Jamed or washer is warned out and it still lets by even though you turned off or room thermostat isn't settled
  11. stevetheplumber
    leaving trvs shut down is what causes them to stick ive found ideally they should be set for comfort and left alone turning the stat down or switching of at programmer is the best way to stop system when not in use
    obviously in this case they need replacing
Loading...
Similar Threads - Radiators won't turn Forum Date
Central heating won't hear radiators? Central Heating Forum Jan 2, 2016
Adding and moving ground floor radiators Central Heating Forum Wednesday at 2:53 PM
New designer radiators filled with iron balls Plumbing Forum Jul 12, 2017
Average price for changing radiators Central Heating Forum Jun 21, 2017
Jaga radiators - any views Central Heating Forum Jun 11, 2017
Sanity check..., gravity hot water and pumped radiators, should they work together Plumbing Forum May 11, 2017
Two leaking cast iron column radiators - victorian style Plumbing Forum May 11, 2017
  1. radiator wont turn off
  • Users found this page by searching for:
