Discuss Radiators won't bleed unless the system is on in the Central Heating Forum area at PlumbersForums.net
Hello. I am sorry to open this with an admission: I made a dumb mistake and am seeking any help possible, thanks in advance ---
The pressure dropped on my boiler, so I opened the usual valve and let it climb up to 1.5 bars. I've not been in this house long, so the boiler is new to me. I closed the valve... or so I thought. I came back later to find an error, and the pressure over 3 bars and climbing. Water was dripping from the boiler pipes in more than one place.
Mildly panicked, I switched off the heating then went around the house and opened the bleed valves on all the radiators. Water came out of one of them, but not the rest. I left the valves open and watched the pressure meter drop over several hours down to 2, and no lower. I closed all the valves, and turned the heating back on. The boiler powers up, and the pressures sits between 2-2.5, but... the radiators do not get hot.
If I bleed the radiators now while the heating is off, nothing happens. No air, no water, no change.
However, if I open a valve while the heating is on, plenty of air comes out, and the radiator will get hot. I've read this is a bad idea, but it seems to be the only way to get hot water into the radiator at all. However, it will not last after I close the bleed valve up again.
If I just turn the heating on and wait several hours, after a time, it seems the boiler will give an error, F37 - which apparently means low pressure (Ferroli boiler) despite still hovering around the 2 bar mark.
Is there a way I can try to reset things again? Any advice would be appreciated. We've just moved house and are hitting a huge number of unexpected costs already, I would really like to avoid professional repairs/new boiler if I can.
Sounds like the gauge is faulty time to call a pro out
Did the system work ie. all radiators getting up to temperature evenly before this episode?
They did, but pressure was dropping regularly apparently.
I think you’re right, I’ve booked someone.
It’s frustrating because I can get the pressure right, and if I open a bleed valve I can get the radiator hot and quite evenly too, but it won’t stay on.
Well, I appreciate the input anyways, cheers
Reply to Radiators won't bleed unless the system is on in the Central Heating Forum area at PlumbersForums.net
