Discuss Radiators vs Underfloor heating large space in the Central Heating Forum area at PlumbersForums.net
J
JamesR8
Is underfloor heating much better than radiators for a largish open plan space? The room is 46 m sq, L shape open plan space with 4.6m of bifolds and another 2m and 3m run of bifold on the L, pitched roof on 3m of the space meaning a bit more than standard ceiling height there, total volume of space is 122m3. Are radiators likely to be worse at heating a big space like this with a large runs of glass?
Is the slab already insulated and tbh on sunny days your going to get quite a bit of thermal gain due to the amount of doors / glass so it go be hard to regulate the heat if you have rads
Wet underfloor is the best thing for this space - but you need to insulate under the slab , then it is surprisingly responsive.
I did this at home when I built a kitchen extension and it is fabulous. My only regret is that at the time I couldn’t be bothered to dig up all the existing floors and put in underfloor everywhere- I should have.
My living room is a large space 7.5 metre by 5 metre, and insulated to current building regs - 150mm in the floor. I was undecided between floating T&G glues and rads vs under floor heating. The central heating system is going to be driven from radiator manifolds with 15mm drops to the rads. Each room has a thermostat controlling its rads.
The issues my friends have had with screeds, and the fear of leaks and issues, I went with T&G floating floor. I currently have a gym in the lounge where we dead live 200KG = no squeaks = on T&G. When under floor goes wrong by the gods you better have deep pockets.
My main issue will be getting rid of the heat in the summer.
Reply to Radiators vs Underfloor heating large space in the Central Heating Forum area at PlumbersForums.net
