Discuss 'Radiatoroutlet.co.uk' column radiators? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has any of you had experience of 'radiatoroutlets.co.uk' column radiators?
The advertised output BTU are impressively high. I asked them and they said they are rated at T50 which sounds better again.
It would be good to get some independent reviews/experiences?
Fitted DQ heating column rads they are a nicely finished product with a good heat output never heard of raidatoroutlets .co.uk , always get mine through a plumbing and heating supplier like plumbcity . Kop
They will be an imported product most probably Chinese and will quite possibly be fine, however as with all products of this nature if you have a problem a couple of years down the line and the supplier has changed manufacturer, because its not a product from a recognised brand you may struggle to get it replaced with an identical which may potentially mean pipework alterations and additional costs which then nullify any saving you've made. The company themselves have two sister companies with the same owners selling LED bulbs so not exactly a specialist in heating.
Please do not use this ccompany. I ordered six radiators over 4 deliveries and every single one was badly damaged. There is no quality control. The sizes on their website are wrong and the BTU values are also a lie. I am currently in legal proceedings with them. Warn all your colleagues and customers, do not use Radiator Outlet. They are the worse supplier I have used in 30 years.
Interesting first post, wouldn`t be a competitor would they 😁
Reply to 'Radiatoroutlet.co.uk' column radiators? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
