Discuss Radiator Manifold question in the Central Heating Forum area at PlumbersForums.net
Hi, if you're installing a manifold to serve each room as it's own zone can you join all rads in that zone from the same port on the manifold?
For example, I've got 14 rads downstairs, there is 2 in the living room. My manifold ports are just 16mm, can I run pipe from 1 port to both these rads?
It'd mean I wouldn't need as large a manifold, maybe it's defeating the purpose by making joints in the floor though
Depends on length (run) and size of rads
over 1.2 I would do each run to a rad
Reply to Radiator Manifold question in the Central Heating Forum area at PlumbersForums.net
