Discuss Rad valve with drain in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
How does the drain on these seal? Is there washer that can be removed?
got a drippy one to sort out
The ones I've come across had a small rubber washer similar to a standard soldered doc
I hate these drain offs with a passion
Reply to Rad valve with drain in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
