Discuss Push fit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
secondery returns run in plastic no no
Copper all day everyday ! Nearly all our site work was crimped copper etc and now they are starting to let you use end feed again ! Do use alot of hep for the temps etc on site and i gotta say the new stuff seems better than the old stuff ! I prefer the johnguest stop ends if its just to blank off first fix ! But you find that people will take the speedfit stop ends off the pipework so when you do come to pressure test you walk round to see your stop ends gone ! So i use hep stop enda now as you need the tool to remove them ! Saying that i sprayed 2 bags of speedfit stop ends one bag blue one bag red and everybody asks whats so special with them i tell them there a special pressure test fitting and funnily enough nobodys robbed them !
Use it rarely, it has its uses but I am an old fasioned copper man myself, seen too many floods even when installed and pressure tested exactly as manufacturer asks for.
Speedfit cap ends is all I use. I very, very rarely use plastic. I've used it twice since being self employed. One recently to join on to the bathroom fitters work and that was literally stick an elbow on his tails and connect to copper. The only time I've used it for myself was fitting an electric shower, the tail poking in to the attic was right between two beams with some flammable looking roof felt inches away!
I really don't like the stuff, it has taken a lot of skill from the trade, it looks awful and I'm sure they've been rigorously tested, but I'm not comfortable with a rubber o-ring being the only thing creating a seal. I'll admit, it does have it advantages, but I just can't get on with it.
Why'd you say that?
Most plastics aren't type approved for use in secondary hot water circulation systems. More to do with the cost of testing before approval for quite a small market than actual compatibility as far as I'm aware. Can't see any issue with using barrier really but the warranty may well be void.
Hep state their pipe is unsuitable for continuous circulation systems so as you say mike the warranty would be void
Interesting, So in theory in a new build care home (worked in loads) you couldn't use hep even for heating because it's run almost continuously? In theory of course.
No because the product has been tested for that application. The water is continuously being replaced with new oxygenated water in a secondary circulation and you cannot us any form of chemical treatment.
Reply to Push fit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
