Discuss Push Fit Fittings and rotating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How far can push fit fittings be rotated after being joined, i need to wallpaper behind a radiator that I don’t want too remove.
I have a pic just know were too host it.
45/90 degrees possible ?
FOUND AWAY TOO ADD THE PIC
Thanks in advance
Steve
Your refering to the radiator valve. The actual pushfit section will not be able to move on that picture. I wouldnt recommend trying to twist the valve at all, if you go to far you’ll get a lot of water coming out.
The photo link wasn’t there when I first replied.
Fitting will turn on the plastic pipe, but I would just have the rad removed
Thanks to the one plumber who did get back to me (rang 10) who I offered the job to remove and refit, he gave me some simple advice so managed to sort myself. 2 Quick Grips, 2 Planks, Folding Stool and a hammer. Job Done
Depends if you’re feeling lucky. I’ve never had a problem although as the old saying goes ‘If it ain’t leaking, don’t touch it’ :)
If you do turn it though and its John Guest fitting try to turn it clock wise with the thread, so the fitting tightens as you turn.
Reply to Push Fit Fittings and rotating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
