Discuss Pump replacement For Celsia pump in the USA area at PlumbersForums.net
Got a celsia pump think it’s myson/potterton sounds like it’s on way out don’t think u can bleed it either .
spoke to anchor pumps recommends grundfos ups2 15/50/60
whats difference compared to ups 3 15/50/65
the ups 2 is a bit pricy would u recommend it
also under pump is gate Valve small bit of limescale On
top of pump is valve with flat head should i drain the whole system
what inhibiter should I use.
boiler 15ri green star only month old
thaks
Reply to Pump replacement For Celsia pump in the USA area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hi Guys, Got a knackered Grundfos UPS 15-60 130. Have a replacement Grundfos UPS3 15-50/65 130. Is the UPS3 pump head compatible with the UPS...
2K
As mentioned in my 'System Drain' thread the house has been extended in 1986. In recent years I felt the circulation was not as good as it should...
2K
I want to replace the three 11 year old Grundfos UPS 15-60 130 pumps as a part of trying to reduce the electricity consumption of my heating/DHW...
6K
Jojomacjo
J
Hi everyone. Bit of a daft question but I’ve just had the pump replaced by the housing group where I live. They’ve fitted a Grundfos UPS3 15-50/65...
1K
