H
harrypearce1
Good morning, I am new to this forum and was after some advice if at all possible, hopefully one of you may be able to point me in the right direction.
The boiler (Suprima 60L) is located in the kitchen with cold water tank and hot water cylinder in the loft. There are two motorised valves in the loft which as I believe one controls the hot water and the other controls the heating. The pump is also in the loft.
When the hot water is running off the boiler (heating completely switched off on the wall programmer) the pump overide doesnt cut the pump off once the hot water is up to temperature and isnt calling to be heated. The pump continuesly runs and gets really hot.
If I am running the heating and hot water together the pump shuts off as it should when the rads & water are up to temperature. If I only run the hot water and then turn the boiler control right down to off the pump will switch off. Could it be that there is a problem with the motorised valve? very confused!!!
I had a new PCB and fan about 3 months ago.
Any advice would be very much appreciated.
Thank you.
Thank you.
