Discuss programmable thermostat to control a Mixer Valve. in the Central Heating Forum area at PlumbersForums.net
I want programmable thermostat to control a Mixer Valve. This to provide CH flow temperature from 30C to 70C from a thermal store tank at 80C
Cylinder tank stat does them ranges
Reply to programmable thermostat to control a Mixer Valve. in the Central Heating Forum area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
