Discuss Problems with air entering central heating system in the Central Heating Forum area at PlumbersForums.net
Air entering central heating system and hot water pumping over into make up tank in artic when h/c control is switched on. There is no problem when only c/h is on! this situation as only occurred since replacing my Grundfos UPS2 with a UPS3
I have tried the pump on different speeds . On the box that the pump came in it stated " Model A" Is there more than 1 UPS 3 models?
Any advice would be greatly appreciated.
Regards.
James
Can you give the exact details from the label on the UPS3, also any idea of what mode/settings you have tried, also a few photos.
Also any idea of what mode/setting the UPS2 was on, did this pump also have LEDs and a setting button.?
If the below is your pump, suggest (if not already tried) CP1, bottom right or PP2, second down on right, hold the setting button for 3 secs until LEDs start flashing, then single presses to get CP1 (3M) constant pressure, or PP2 (3.8M) proportional pressure as indicated by the flashing LEDs sequence.
Reply to Problems with air entering central heating system in the Central Heating Forum area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
1K
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
