Discuss Problem with old towel rad pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
My first post here and after a little advice, please.
I have a downstairs shower room and the old towel rail (now thrown away) had pipes that are under the concrete floor. Since throwing the old rad and refurbishing the room I’ve noticed the pipes are an odd size.
The centres are 425mm and can’t find another rad anywhere that fits this size.
I have picked up a 450mm wide towel rad from my local merchant and the centres on this are 410mm.
Is there any way that I can bring the old pipes in somehow without getting a plumber round to sort it??
Am I able to use plastic via compression fits to the existing copper coming out the floor??
Was thinking this way there would be some flex to make up the additional 7.5mm each side?
Hopefully this makes sense.
Thank you
Chris
Thanks for the reply, only problem is I don’t have a pipe bender and working on a tight budget. I was going to use the chrome cover you can get.
I was just unsure as to whether I could go from the fittings already there, to the rad but in plastic and pressure fits? If so, what would I need to buy exactly??
Thanks again
You can use compression fittings coming out the floor and then go to plastic, it would look untidy though and as the pipe wouldn't be straight, the chrome wrap you mention wouldn't go round it all that well. Personally I would take the towel rail back and shop around, there will be towel rails that fit 425mm centres.
Any pics of the existing rad ?
Reply to Problem with old towel rad pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
