Discuss Pressure release valves in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Anyone finding these 'failing' early? I'm in Ireland and have never seen these valves opening under normal conditions. Recently, in the last year, I have had three brand new PRVs opening under normal conditions. One of them was on the mains supply which actually has a pressure reducing valve on it anyway, so why would it open? Another is on a gravity fed system which is never going to reach normal mains pressure! Maybe that's the issue that they aren't 'pressurising' the valve enough. The third one is off the cylinder. All from joule. Any thoughts thanks.
Are you using the balanced cold for outlets or piping straight off the mains eg before prv ?
Unusual if they are not approaching/ exceeding their set pressure, you should feel resistance when you turn the lifting knob anticlockwise and hear a click when the valve reseats, ifyou do then coud be a problem with seat material?
Reply to Pressure release valves in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
