Discuss Pressure issues or controls? in the Central Heating Forum area at PlumbersForums.net
C
Carlos87
I have a worcester Bosch greenstar CDI compact that’s around 6 years old. Over the last few months I’ve noticed the pressure when the heating isn’t on drops to 0 and if I flick the Salus control on the boiler to on nothing happens and the boiler light stays off.
What I have since worked out is that instead of flicking the control on the boiler to on if I use the portable salus thermostat to ‘up the temperature’ the boiler light comes on and the pressure slowly raises to a reasonable level and we have heating again.
The first few times this happened I topped the water up to 1 thinking it was a leak but when the heating came on it then started shooting up to 3.5 and had to let some out.
I’m starting to think it’s an issues with the control on the boiler but can’t work out why the pressure drops to zero each time.
Does anyone have any idea what this could be?
Needs a decent service also a couple of parts / seals replaced as it’s blown out of the prv
Reply to Pressure issues or controls? in the Central Heating Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
