Discuss pressure differential diverter valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
lordyjordy111
Hi lads
have just started doing a few breakdowns for my boss and would like to pose a question.
I have just put an overhaul washer kit on a pressure differential diverter valve (front pin) on main combi 30 he
I know how that part works.... venturi etc but what moves the second pin at the back. that has a small washer aswell but
my tech books only cover the front part.
is the back one connected to the heating circuit thus must be pushed up when the pump operates?
cheers
from memory the back part is spring loaded against the front part and moves with the front operation
Is he talking about the pump proving?
hi
yes i think i am
on this divertor if your run a cold tap the front pin pushes out and then the back one pushes up.
my understanding is the mains water pressure via a venturi moves the front pin but what moves the second pin
(according to the MI's this second pin is connected to the hydraulic pressure differential switch)
is it connected to the heating circuit and as you say is a pump proving mechanism???
as you said press diff moves the front assy pin and the rear follows as its spring loaded . water press pushes it back from front assy
Reply to pressure differential diverter valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
Hi new to this forum, hope someone will have the answer to my issue. I have Recently had a new Diverter valve brass body and motor replaced on my...
2K
Hi everyone, I'm a (somewhat, I hope...) competent DIYer and just want to get some advice if my suspicion on a problem we're having is correct...
Ideal boiler loosing pressure (AT WITS END) Hi all looking to converse about my boiler problem with people with knowledge. I’d be grateful for...
5K
Hi all, I am hoping that I can pick your brains again. I have just installed an Ancona 1800mm high and 10 double columns wide radiator. This...
2K
