Discuss Pressure- bar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
localhero
Hi all new to site, i've removed a 3 rads & replaced them but i only connected 1 with the other 2 closed at the trv's. I've bleed the system which is fine however the pressue gauge keeps dropping to 0.5 after i've filled it up to 1-2 bar i have to refill in order to get hot tap water... thanks
so im assuming you only put 1 back on the wall and the other 2 are just shut valves not connected to any rad
Trv's arnt connected & havnt got end caps on pressure drops 20-30mins from 2bar
well i would cap them for starters even if they haven't leaked yet, any signs of water near the valves?
No water capped them off, will refil to 2bar wiil get back.. thanks
Awheating : yes when the hot water runs or heating, i just filled up to 2bar turned ho****er tap on (kitchen) went up to 2bar+
The pessure gauge is still decreasing, i filled it up 1/1 12bar 20mins ago now in the red??
you didn't drain the heating down with the prv did you?
i know a few who use that trick
No just shut the rads of at trv's drained radiator, then connected 1 opened the bleed screw until water came out off it. Other rads arnt connected
do you know how to reset the prv? I am sure in one of your earlier posts you sad you could see water coming from the pipe out side?
Not sure how to do that, water from the overflow when hot wter or heating was turned on
trace the pipe that goes outside back to the boiler there should be a red valve twist it a little to the right you should here water flow out or not if it is stuck in the open position
then twist it to left till you can't you shouldn't use any force when doing it, sometimes they wont reset but at the rate its dropping you should see an improvement
Yeah turned it water came out, the water hasnt been coming out of that pipe it was the plastic pipe but that was just a drip when turning the hot water on!! It loses pressure when idle not when in use!! Could it be that because a rad is disconnected.
oh dear, you mean the condense pipe? yea its supposed to
its a lot of water to be loosing in a short amount of time should't be that hard to find you did fill all the rads properly and bleed them?
Just been around again to double check them, turned heating on & re bled all ok nice & hot doesnt seam like any trapped air blocks..
Thanks for your help
Reply to Pressure- bar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
the pressure of my boiler looks unstable After i re-pressurize to 1.5 bar, using tap is ok without problem. but when turn on the central heating...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
In our sealed Megalo system, when hot water tap is used (say in bathroom shower) the megaflo is taking in some fresh water, I guess to compensate...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
