Discuss Pre pay gas not working Vaillant Boiler in the Gas Engineers Forum area at PlumbersForums.net
Hi recently my pre paid gas ran out. I checked and I had 15 credits. I know my mums boiler had the same issue where it shuts off if there are only 15 credits left. She tells me an engineer comes and does something that takes 2 seconds and its working but he never told her why. Its a Vaillant boiler I tried topping up another £10 and put the card in to release gas and gas meter shows "o" which I think means on. No gas appliances in house to check gas supply. It is showing either F28 or F29 when I reset. Anyone any ideas?
If it’s a smart meter, you may need to wait 60 - 120 seconds before relighting the appliance. This is a safety feature if the gas meter to prevent a buildup of gas in the appliance.
If you press button a, does it tell you on screen if the gas is on (It should do)? Have you pressed the reset button on boiler for approx 10 seconds? Does the boiler reset and then fail to F28?
Button A doesnt do anything for me. Whether I press it, hold it nothing happens. If I press button B it tells me to hold it in to release gas but nothing appears to happen when I release it.
Yes when i use the reset button the yellow light goes on and off about 5 times then the red light and f28 error.
So basically the gas isn’t getting to the boiler. If you’re pressing button B and holding it, but nothing happens, then it could be the meter. Normally it will state in screen opening valve, and then you’ll hear a clunk, which is it opening. F28 will be a lack of gas to the appliance and has failed safe.
Well I have tried a few times, it may have worked the first time. I just checked the manual for my meter and according to the manual the o in the bottom left corner shows that the gas valve is open.
After some googling I seen it suggested that it could be low gas pressure?
I recently ran out of electric after my gas run out and before I could top it up would this affect anything?
It shouldn’t affect anything. Low gas pressure would be the transporter. is the emergency control valve fully up?
Reply to Pre pay gas not working Vaillant Boiler in the Gas Engineers Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
