Discuss Powermax no/tepid hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
John Cotton
I have a Powermax (thermal store) boiler. When the central heating and hot water is on there is hardly any hot water at all - and when only the hot water is on there is some but its tepid at best. ANY IDEAS ????
has this happened over a period of time ?
No , happened all of a sudden. Hot water comes through taps for a few seconds, then goes tepid / cold.
does the boiler run ok in just hw mode ?
is the pipes feeding the coil hot ?
has it got a blending valve fitted ?
Reply to Powermax no/tepid hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
