Discuss Power Shower Issue: Advice please! in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
T
TGILL91
Hi all,
Just looking for some advice - moved into a new property in last 3 months.
Today when taking a shower, AQUALISA Power Shower cut-out, and when tried to turn back on - v.low water flow coming through.
Finished the shower in another bathroom - water pressure was fine for that shower (non-electric).
Left it 10mins and tried to turn the electric shower on again, seems somewhat noisy, and the water temperature is very hot (even at low settings). So have left it for now.
I'm OK with DIY but not a plumbing expert - is this something I need to get a tradesman out for, any ideas on issue?
Thanks so much
Reply to Power Shower Issue: Advice please! in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I'm looking for a water pump to pump water from a storage tank at a constant 3 bar pressure. It's at a campsite I run that's at the bottom of a long, steep hill. We struggle with very high and often fluctuating (around 7 bar) water pressure, which wreaks havoc with our water heaters. I've...
