Discuss Potterton Suprima 50L in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes, I know, get a new one . Fires up (only using HW at mo), runs, burner on say 10-15mins then cuts out (flashing red), hold red, yellow flash once after 3 secs flashes again, after reset will work again sometimes until demand time complete. Think this indicates an ignition fault but if that's the case why when cuts out during burning!! New type pcb fitted 2009 thermistor 2014, Flushed last week with chemicals and new inhibitor as thought that might be the fault, any ideas welcome.
You need an engineer to have a look to be honest. Could be a few things. Dependant on what board you have. I know you said 09 for the board but doesn’t mean much
Even then. It can be more than 1 thing. Needs testing properly by a qualified engineer mate.
Closed
Get a gas safe engy out this forum isn’t for diy repairs or fault finding on fuel burning appliances unless your qualified
Reply to Potterton Suprima 50L in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a customer with a Potterton Suprima boiler that keeps locking out with a red flashing light. If you reset the boiler it fires up fine and...
6K
Deleted member 120897
Hello, recently our boiler stopped working properly, causing a lack of heat in our 14-radiator splitter in 3 storeys. having only one boiler at...
Hello - I have a weird issue with a potterton suprima 60 with the old type of PCB with the round reset button (not Siemens). I just replaced the...
HI everyone. I have an old Potterton Suprima HE 60. Was going to replace when we get our extension next year but of course it's started to play...
2K
  • Locked
Switched the boiler off at fused spur then switched it on again. Boiler's working with both heating and hot water but the LED is rapidly flashing...
