Discuss Potterton Promax HE 15 2004 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Lee Davies
er
OK, so here is an update on this boiler to see if anyone else is the wiser.
I actually got longer than 15 minutes in the property today.
I cleaned out the condensation trap, this was blocked, therefore causing the boiler to lockout. The trap was full of 14 years worth of aluminium by the looks of it from the HE.
Checked the case seals on the CC and they are not passing, therefor I didn't remove the combustion chamber door and it isn't the overheat stat on the fan causing lockout.
Fan is working correctly, 3 port valve is working correctly, pump is working correctly, electrodes are sparking correctly (I removed them to check spark strength and clean).
The issue is now as follows.
Programmer comes on for water or heating, 3 port switches to the correct side, pump is permanently running. boiler acknowledges that there is demand and the fan kicks in. Electrodes spark as they should. Here is where the problem now lies as "sometimes" the boiler will try 5 times and then lockout, sometimes it will fire up first time, sometimes it tries once or twice.
My gut feeling is the solenoid on the gas valve is being dicky, or the Ignition PCB has an intermitent fault anyone else have any ideas?
Customer is also asking, due to the age of the boiler and possibility of other future issues, is it more economical to replace the boiler with something like a Viessmann Vitodens 16KW open vent?
Regards
P>S I have submitted my gas safe number to Harvest Fields so I can post in the private section.
Could be repaired but go with your gut feeling the solenoid is easy enough to check , PCB probably around £100 but in all honesty I would be pushing them towards a upgrade , and a service plan which they have neglected by the deposits you have found in the condense trap it wont be aluminium in there as the heat ex is stainless on these. Kop
Test the gas valve eg put meter on inlet and turn the gas off if the manometer drops it’s working but if it starts doing what you say and doesn’t drop gas valve could be at fault
So test if it’s gettinh the call voltage if not pcb
But tbh new boiler good choice on a 100w :)
No gas safe badge mate , is it on its way ?
If you mean my GSR badge I have given my details to admin via pm WEEKS ago, I sent it to Harvest Fields today so hopefully he can help out.
Can't believe I didn't think of that earlier.
Thanks again.
Reply to Potterton Promax HE 15 2004 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
Hi new to this forum, hope someone will have the answer to my issue. I have Recently had a new Diverter valve brass body and motor replaced on my...
2K
Apologies if this has been answered elsewhere, but my family and I are starting to crack. I'll start at the beginning, and maybe someone will see...
2K
  • Locked
I have a Potterton Promax 15 HE from around 2005. When I put the hot water on for an hour or central heating, the boiler runs for about ten...
N
Hi All I know I know ... another HE24 LF code problem. Fix is replace boiler ;-) My problem is slightly different to other posts I've been...
3K
Mikesin
M
