Discuss Potterton profile, ch works ok. hw works but rads get hot also. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Going to this job tomorrow.
The central heating works ok, goes on on and off when it should.
The boiler fires ok when there is a demand for HW but then the rads get hot too.
Apparently it's had a brand new three port put in last week but the fault still continues.
Programmer?
What else could it be?
Check that they've actually changed the 3 port and not just the head.
I'd look at the 3 port too first, its not uncommon for new parts to be faulty aswell
apart from what everyone else has said,have you asked if its a new fault or existing? can only be as already mentioned if recent but if existing last T rule has not been followed
I thought the guy only changed the head but he swears he changed the whole thing otherwise that's what i would have done first. I think he's going back today with a new programmer.
If you have 240v on white as well as orange with only HW on then double check the wiring. If you don't have 240v on white and it is still passing through the 3 port then he has probably only changed the head.
I have had a few cheap valves pass from brand new as well so it may be down to that.
If it is not circulating through the 3 port then it will probably be piped up wrong, if it is only just showing up after years the chances are someone has fitted a nrv and it's stuck open.
Reply to Potterton profile, ch works ok. hw works but rads get hot also. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
G
I've just bought a 3-floor house with a gas boiler on the ground floor and hot water tank on the middle floor. When I switch on the hot water at...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
