Discuss potterton prima 40f in the Plumbing Jobs | The Job-board area at PlumbersForums.net
buckley plumb
been to this boiler to day and the last 3" of the inner flue have corroded. i have ordered the inner flue kit. potterton seem to think this will slide over the old inner flue . i noticed part way down the flue is a 4mm steel rod which goes through both inner and outer flue sections i am hoping the new inner slides over the old inner as to replace the whole flue is a boiler off the wall job. i was going to cut this rod if need be top and bottom and pull the inner part out and fit the new inner all the way to the fan spigot .this rod just being there to hold inner and outer together i assume .i am ordering the inner flue from a online merchant as its half the price of pottertons.potterton.anyone done a flue on one of these.
ant
No,you have to remove the inner flue,you leave the outer flue section
Thats all I will say on the open forums,as this is defiantly a job for a gsr operative
imho
imho
is it ok to remove the rod part and fit the new inner all the way to the fan spigot.
ant
just spoke to potterton tech and was suprised at the proper repair method ?
ant
ant
As said instructions in box..Takes about 30 mins to do and is a doodle, Belive me , done loads...The new inner flue (cut to your required length) slips over the damaged inner flue
Reply to potterton prima 40f in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I have an issue with my potterton prima boiler and would love some help. It works fine when either CH or HW are on but when they are...
2K
Evening all. Can anyone help me with a bit of advice. We “inherited“ a Potterton Prima 60F boiler (which we were told in 2013 was 3/4 years old)...
Deleted member 120897
I have an old Potterton suprima boiler with a hot water tank and pump. We have hot water but no heating, the light on the boiler is showing amber...
2K
Hey all Looking for a consensus on an issue that has arisen. Disclaimer is that my ideal icos 12 boiler Is over 10 years old but has been...
2K
