Discuss Potterton heatmax in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kyle87
So seen it in pts with a half decent price. Coming with a clock and flue.
To my inexperienced eyes it looks identical to a duo tec - the clock.
I know baxi and potterton are all run by BDR Thermea so it makes seance I they are virtually the same and sold with different badges.
Question!!........
Are they the same?
If not, are they any good?
heatmax/promax-2 yw duotec HEA/TITANIUM-7yw plat-10yw
Really is that all.
Sod that then.
Yea 7 and ten year on the baxi is what we've been told. Didn't know the warranty on the heat max would be so bad
Just buy a platinum. 10 years p&l magnaclean rf stat inhibitor, sludge and flux & telescopic flue ÂŁ1045 inc
No but I did expect more than a biasi warranty
Pay biasi money get Baxi boiler but biasi warranty. Be honest though..... Duo tec 1 how many faults occur? Spark electrodes after about 3 to 5 years...... Some times Hall effect sensor but not much else. Parts are cheap and readily available. If you fit a max, if it lasts for 7 years bin it and get anew one with the money you save! Baxi may have release duo tec 3 by then and be in the process of withdrawing it!
BAXI DUO-TEC 28HE CENTERRAD HEAT PACK @ 869 + vat.(boiler,flue,TRV's & LS valves & 7 RADS up to 35,000 BTU'S) To unsub txt NO to 60022
Reply to Potterton heatmax in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can I jump in here rather than starting a new thread about the same thing? We were about to start getting quotes for a new combi (just moved into a house with a 10 yr old Vokera) and it's now packed up on us. Heat exchanger is bust so we're topping it up every 3 hrs. Anyway. Quotes and boilers...
9K
  • Locked
Hello Members, I'd like some advice on which boiler to select between Main 30Kw and Potterton 28 Gold boiler. This is for a 2 bed 2 bath flat. Currently have an old worcester boiler that needs to be replaced. Its a rented property. Price for Main 30 Combi incl standard Flu and clock ÂŁ700...
1K
  • Locked
Registering a boiler I've just fitted on the Gas safe website and as I nearly always usually fit Worcesters have never seen the 'warranty registration' option, now that im registering a Baxi Duo-tec... The home owner is elderly so i suggested I try and register their warranty for them over the...
  • Locked
Hi all I wondered if someone could give me a bit of advice. I have a Back Boiler that has been condemned as it is leaking fumes which aren't all being expelled up the flue and so need to replace it with a Combi boiler. The Back Boiler is of course located behind the fireplace in the living...
13K
stoker122
  • Locked
Just got a job to which i ive sold a potterton gold 28he combi to a customer on the basis that its exactly the same as a duo tec/platinum just badged differently. Is there a diff between them??? if so could someone tell me....even if it something little as i'm intrigued as the price diff is a...
6K
