Discuss Position/location of bath overflow in the USA area at PlumbersForums.net
I’ve just moved in to a brand new build apartment and when trying to bathe noticed that the bath overflow (also a twist and pop up plug) is directly in the centre of the bath depth at the tap end. This means that you can only run a shallow bath as obviously when you are in the bath you don’t even get half a baths worth of water with your body in there.
The second problem is that the tap is positioned in such a way that the water runs on to the protruding overflow meaning that the water you run is simply spray. This means by the time the spray has entered the bath, it’s cold. Any advice please?
  • IMG_0001.MOV
    25.9 MB
Had to chuckle at that.
1. Never seen an overflow that low. To be honest never seen a bath that the overflow and waste haven't been pre drilled. To fix that then it's a new bath.
2. Should be able to get something to re direct the nozzle. Might not be pretty though. Temporary repair or fix would be to cut a small drinks bottle in half and take the cap off and tape over the spout.
But if it's new build then get them to sort.
they will say something like it’s to conserve water :D
Reply to Position/location of bath overflow in the USA area at PlumbersForums.net
C
Hi - I have just had a bath replaced during a bathroom renovation and the plug is now in the centre of the bath rather than at the end. It also...
1K
Existing bath overflow and waste was a pop up and its broken, so needs replacing. Not going for a popup again. My requirements are - good water...
2K
Hello All, Hoping for a bit of advice/info in this one: My Setup Small system in apartment with cold tank above hot tank in the hotpress, so...
2K
Hi everyone, I had my gas combi boiler serviced last month and the engineer completed the job, filled out the paperwork and said it was in good...
3K
Hello - am hoping someone out there can offer some advice... I've been living in a split level 1st & 2nd floor masionette for two months, which...
4K
