Discuss Pop Up Waste Suits Overflow & Non-overflow Basins in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Everyone,
I recently brought a replacement Pop Up Waste from Argent K316-DL & the spec states it suits both overflow & non-overflow basins.
However it has no slotted waste opening. How could this be used with sinks with an overflow hole & still prevent sink overflow?
Natalie
Argent Pop Up Waste Spec
Drill a hole in it when an overflow is required
I can't tell if you're joking or not. If you're serious and its easy enough to do it might get me out the s*** occasionally
OP: I think I've found what you've chosen and it does indeed do both. They are in 2 parts and clamp top and bottom with a gap in between for the overflow or no overflow depending on which basin . They are a good design, have fitted 100's of them in an estate
Yep you could even do two 6mm and join them to make a slot etc got me out the doo when I only had an unslotted waste on the van tested the overflow and couldn’t see any difference
Thanks for your reply, I was ready to return it. This morning I found the install instructions on the Argent site, attached. There is a foam seal that goes above the basin & a silicon seal that fits under, picture attached.
I had googled yesterday & in Australia it seems this is rare all the comms referenced 2 distinct types for over flow & non-overflow basins.
  • Argent K316-D Variants Wastes Installation Instructions.pdf
Some old shower trays used to have included overflow, pretty sure it was ideal standard. You had to cut the waste to connect the overflow.
Reply to Pop Up Waste Suits Overflow & Non-overflow Basins in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
