Currently reading:
Pool heating options....
Discuss Pool heating options.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks. A friend of mine is installing an infinity pool, ( for those who don't know what they are, they are a small pool maybe 10ft x 6ft and are pump so you can swim against the current without reaching the edge) he has asked me if I can hear it via his farm 2000, a large wood burner. I regularly service oil fired pool heaters, and I've seen the air source heaters. But anyone know of anyway of incorporating the existing system, ie heat exchanger?? Would it work? How would I control it? It needs to be able to heat to around 28degrees so I've read, would this be achievable? Anybody ever tried this?
Ive a feeling it's going to be a separate heat source direct to pool but any advice?
Loving the way a naughty word is taken out of S****horpe in the location.
Not necessarily,
I have heated a 8000 ltr pool off a 30 kW boiler, via a heat exchanger, while also doing ufh and rads of the same boiler.
The rads and ufh pretty much maxed out the boiler capacity, so I was sceptical.
The pool was as add - on to the original specs, but the customer was willing to take a chance.
Once it was set up and running - have had no complaints, and the pool is / was heating up to 28 C without a problem
What the volume of water in the pool? - there are limitations to this
An infinity pool will lose heat a lot quicker than a 'static' pool when it's running. Saying that, it can only lose heat to the surrounding air and if the building it's in is well insulated and has some sort of heat recovery then it's not going to be such an issue.
You could quite easily incorporate a plate heat exchanger into the mix from an existing heat source as well as a GSHP or HSHP. All very doable for someone who knows what they're doing.
Reply to Pool heating options.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
