Discuss Plumbing an island sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I am in the process of planning my single storey extensions plumbing and drainage.
Our kitchen plan has an island with a sink in it and im trying to work out how to get waste in and hot cold supply.
I am having a solid floor construction of 150mm gravel, sand, dpm, concrete. Then in prep for underfloor heating - celotex with a 70mm screed on top.
My thoughts are waste pipe between celotex and concrete maybe a form adding to concrete and sculpted celotex. The same for hot and cold supply potentially ran in another length of pvc pipe to protect them? Waste would be plumbed into new 110mm external drainage. Any advice welcomed as I will be doing all plumbing inclusive of drainage to cut down on cost. Thanks
Sounds about right as long as it isn't over a massive distance. (Waste pipe). Could be wrong but 70mm sounds excessive.
If it's more than a 3m run then you will need 50mm waste pipe , solvent weld fittings and pipe , hot and cold pipework I would use hep 2o pipe in pipe strapped to the concrete slab under the celotex. Cheers kop
Thanks Kop, how do you plumb the waste trap as a normal one is horizontal and this will be vertical?
Are you making allowances for getting power to the Island as well?
Hi Snowhead, yes I am there will only be a requirement for a pop up socket so will incorporate that as part of the ring main for the sockets, again I was thinking to run this thru plastic conduit again.
Reply to Plumbing an island sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
