Discuss Plate heat exchanger and Indirect Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
redapple
Hi I was wondering if I might be able to get some help. I currently have a gravity system and a indirect Cylinder. I noticed that their is for sale unvented indirect cylinders with heat exchangers attached to increase recovery . mcdonald-engineers powerflow cylinders. I would convert to a unvented system but need to upgrade street mains and it would cost me nearly £2000-3000. which in the current climate is not possible for maybe at a later date. I wondering if it possible to attached a plate heat exchanger to a vented indirect cyclinder to increase recovery time. I came up with a design. Not sure if its right. any advice would be much appreciated.
http://i48.tinypic.com/2cgc2sn.jpg - for large picture
Have a look at indirect high recovery cylinders. There are quite a few on the market.
thanks, i was looking at albion superduty High recovery 250L? is this too big or too small to meet my demands. thank you for the help. current tank is about 110l and running out too quickly and taking too long to recover
The theory is simple but the practice is less so.
Only you know what your hot water demand is and you may find a small HR cylinder perfectly adequate for one shower used several times in quick succession. Also the smaller the storage capacity the more cost effective the installation and running costs would be.
If you have more than one shower and a house full of teenage daughters you may need to go for a bigger capacity cylinder and low flow aerated shower heads.
Remember that buying fresh and disposing of waste water is getting really expensive nowadays.
Reply to Plate heat exchanger and Indirect Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am fitting new taps and a shower mixer in my en-suite and was looking to isolate the hot water pipes. I have an unvented indirect...
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future...
Hi all, looking for some recommendations for a slimline indirect unvented cylinder to go with a new system boiler that we're having installed...
Hi, I have two indirect water cylinders (Gledhill) connected to a gas boiler (Vaillant). The system is setup/programmed so that the tanks heat up...
Trying to add a shower into a small bathroom, I'm looking at moving my hot water cylinder to the loft. Currently, I have a vented 200L cylinder...
