Discuss Plastic clamping system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bdell
I recently returned from a holiday to New Zealand and found that the majority of new build houses are plumbed with a plastic clamping system called Buteline. Has anybody heard of this type of system and is it avaliable in the UK?
yep, polybutylene, its used here in the UK in new builds also. Easy and quick to fit, but costly compared to the standard copper/end feed.
Reply to Plastic clamping system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
