Discuss Pipe work a little bit short what can I do? in the DIY Plumbing Forum area at PlumbersForums.net
Hi, my pipe work is a little bit short it is plastic pipe 10mm will a 10mm coupler be okay to use to extend it to fit the valve?
If you’re short, yes, use a coupling, unless you can fit a new piece? Photo would have been
If you’re short, yes, use a coupling, unless you can fit a new piece? Photo would have been helpful.
The radiator ( current one) is 500mm wide and I want a 600mm wide one to replace it I was thinking a coupling could do it? Any help I would be grateful for I’m learning all the time :)
Reply to Pipe work a little bit short what can I do? in the DIY Plumbing Forum area at PlumbersForums.net
