Discuss Pipe sticking out of the wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It's about 300mm off the floorHow high / low on the wall is it?
It's capped off with what looks like a flat head screw top not a compression fittingIt could it be a metal conduit for a cooker point? Is it open or is it capped off?
In that case it could be a gas pipe for a cooker bayonet fitting. It could still be live so best not touch it until you get it checked out by a gsr to be safe.It's capped off with what looks like a flat head screw top not a compression fitting
Thanks Darren my fridge freezer is going there so hopefully it won't be in the wayIn that case it could be a gas pipe for a cooker bayonet fitting. It could still be live so best not touch it until you get it checked out by a gsr to be safe.
Reply to Pipe sticking out of the wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
