Discuss Pipe layout question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello
Can you help I need some advice regarding the layout of some central heating pipes i have an obstacle I need to route the pipes over and just really would like to know if my plan will work without causing any problems I was going to tee off then across a bit. then up the offset will only be 50mm up then over the obstacle then back down 50mm I have attached a rough drawing of the plan any help is appreciated thanks steve
Cant see a problem with it steve. Whats the pipe going to? What size is the pipe and what type of system do you have?
Evening what is the obstacle you are going around and where is it and why are you doing it? I.e extra radiator?
On the drawing where it tee's off half way across where I want to jump over the rsj the pipes drop downstairs basically i want to move the pipes over as the walls being battened then plasterboarded over so they can be hidden I have uploaded a picture the red line is where the rsj is and the blue lines are where I want to drop the pipes thanks
On the drawing where it tee's off half way across where I want to jump over the rsj the pipes drop downstairs basically i want to move the pipes over as the walls being battened then plasterboarded over so they can be hidden I have uploaded a picture the red line is where the rsj is and the blue lines are where I want to drop the pipes thanksView attachment 31166
If the wall is being battened. And plasterboarded can they not be routed inside the fake wall?
Picture one in green is where I want to come up from under the floorboards then travel over the top of the floorboards around half a meter clearing the rsj then back out in picture two then drop back down under the floorboards then down the wall cheers
Picture one in green is where I want to come up from under the floorboards then travel over the top of the floorboards around half a meter clearing the rsj then back out in picture two then drop back down under the floorboards then down the wall cheersView attachment 31168 View attachment 31169
It should work. And there is already pipework ran above the floor in there anyway. Not ideal but will be ok.
Reply to Pipe layout question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
