Discuss Pipe depth issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
Want to replace my existing 15mm shared water supply for obvious reasons. The current supply in my 1935 built house is around 150mm below ground level outside and around 450mm internally (no DPM).
My issue is, for me to enter the house 750mm below ground level outside, I will need to drill through the foundations. Will seven Trent expect me to do that? Foundations are around 650mm below ground level externally.
Thanks in advance
yes also you will have to sort the pipework out they will just connect there side eg stop tap
unless your paying them for the whole job?
Thanks, was hoping I wouldn't have to do that. All seems very extreme as never had issues with current supply freezing, and as afar as I know, UK has never had a frost below 6 inches.
Usual overkill to charge more I think.
i seen it go to a foot on the frost line, depends where you are
was around -20 last year my area without the wind chill
2'6" was in the 1950s model water by-laws, so nothing new. Probably also something to do with keeping the water reasonably cool in summer and to avoid drying and wetting of the ground from stressing the pipe.
also less of a risk eg damage from people digging
Reply to Pipe depth issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
