Discuss Pipe coupler issue - connecting two male fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there
I'm trying to connect two male 15mm x 3/4 inch pipe connectors together. Can anyone advise the adapter I need and where to buy it from? The problem is shown below.
Note: This issue occurred because I am trying to tee off from the kitchen cold water pipe to supply an outside tap. I am using this product from Screwfix as tee (visible at the bottom of the picture above), but both ends of this part are male.
Edward
Welcome to the forum.
Bit of copper pipe into the two compression ends. Although better to hard pipe rather than flexi's.
Don't do a garden tap with flexis. Hard pipe with individual ISO and check valve
I'm with Riley. But if you have no choice use a small piece of 15mm pipe with the union and olives you already have left over. Not ideal to use flexi's though rigid is better
Thanks everyone for your very quick feedback!
1) Appreciate the advice regarding the hard pipe rather than flexi - I will replace that so only hard pipe goes to the tap.
2) However, there is already a flexi-pipe going to the kitchen tap and that's what I am attempting to Tee off of. I still have the issue of connecting those two male connectors
@SimonG thanks for your suggestion, although I'm not sure I understand :S How is the copper pipe going to stay fixed to those screws?
It looks to me like you're you're using the wrong sort of tee piece to try and join it all up. Any chance of a picture a little further back?
Before you removed the flexi connector there would have been a threaded nut(Union) with an olive inserted in to it. You put the 15mm copper pipe into the two things that you are trying to connect and tighten the nut and olives up onto the threaded parts of the fittings. That is how they stay connected.
Hi Riley. Below is a picture of the kitchen water supply pipe before I separated it in order to try and fit in the tee join.
It should give you the full picture of all the connectors involved. Full details of the tee piece are on Screwfix here.
Think a normal compression tee would've made life easier so basically you have 15mm grey pipe water in, compression tee, two 15mm copper stalks out of the two remaining gaps in the tee.
Isolation valve, copper, check valve, copper to garden tap.
Isolation valve, copper to kitchen tap
I'm amazed that such product isn't easy to find. It must surely be a fairly common problem, or perhaps I am doing something completely wrong:(
This would be what you appear to need;
http://www.toolstation.com/shop/p24305?searchstr=1/2" socket
BUT it is NOT the correct fitting for the job.
Both ends need a compression nut, olive (compression ring) and then a single short piece of 15mm pipe.
You must have had 2 nuts and 2 olives with the tee?
I assume you've joined the Tee to the nut / olive on the plastic pipe?
It would be simpler to put the flexi back as it was and fit the Tee into the plastic pipe using inserts in the pipe to stop it being crushed by the olives.
Thanks for your suggestion. Another issue is that I cannot get good access to the plastic pipe - literally that connector you see in the picture is the limit of my access without taking appart my kitchen worktop. So i'd like to somehow put a T in there.
Will have to assess the situation when home this evening and review all the comments in this email to determine next step.
That looks like a washing machine tee with iso valve, but does not look like 3/4", they tend to be wider and less turns on it.
That must be 15mm nut and olive fitting surely? attached to pipe.
Then pipe attaches to flexi as it did before and goes onto tap.
Was that tee there before or did you do it?
Ok I know this is a very late contribution, but I simply cannot believe that nobody has mentioned changing the flexi to one which has a 15mm x 1/2" female compression to connect that male threaded tee?? However, even if the flexi was suitable for the purpose of supplying an outside tap (which it isn't), I still can't comprehend why one would suggest joining 2 male threads together with a bit of offcut pipe and compression nuts over simply replacing the flexi with a female thread and rubber washer!
Because what you are saying is bad advice as the male thread on the isolation valve has a raised edge which will cut into the rubber washer on the female threaded part of the union causing the fitting to leak over time!
Well, what is the purpose of a female union if it isn't to connect to a male thread (please don't say to connect to a female thread with pipe offcut!)? I would never recommend connecting two males together with a very short or practically nonexistent offcut as when the unions are tightened, there isn't enough strength in the offcut to withstand the tightening and therefore a leak occurs.
The strength is the copper pipe inside both female unions.
For the hard of reading.
You would not connect a flexi conn onto a fitting designed for an olive. It will cut the rubber washer and leak.
Bad advice to suggest otherwise.
They are designed for a male connector with a flat edge. Not a raised edge.
I was trying to be nice mate. But your point sounds much better:p:p:p
the nut on a tap connector itsnt a female iron its a loose nut with a pressed rubber washer
Ah right, I see. I didn't realise there were 2 types of edges - thought they were all with raised edges. I can totally understand that then. Thanks for pointing that out. By the way I'm not a plumber, just a DIYer plumber :D
Well thing is, I've attempted to bridge two fittings together with a small offcut 15mm copper where the two fittings were practically touching each other, but when I tightened everything, it did actually weep so had to replace the offcut with a longer one. Yet, I've seen a plumber by trade do exactly the same thing and he tightened it so hard the fittings actually squeaked, yet his didn't leak!
the squeak is how you know there correctly tighten
i normally use wras approved jointing compound which helps stop the fitting squeak
you will soon find how much to tighten compression fittings just takes some practice
Well, rather than using an offcut to connect two fittings closely together, lets say for instance a PRV and an inlet strainer upstream of it, would a female to female equal bush still be sufficient?
Definitely true what they say you learn something new everyday (awesome to learn about those two male edges)
I would use a female threaded prv and line strainer
Male iron prv short nipple strainer male iron
Is this in your home?
In a holiday home abroad where the water pressure is so high that it's ruining kitchen fittings etc. I've already bought my PRV and inlet strainer, but the thing is, due to cold winters, piping is all done in PPR so I want to avoid the use of copper. Sorry this thread has deviated slightly.
Thanks but hmm it's tricky for me to understand and visualise. Perhaps a link would help. But would my fittings be adequate?
RELIANCE PREDATOR ADJUSTABLE 1-6 BAR PRESSURE REDUCING VALVE 15MM WITH GUAGE PRV | eBay
Bsp Female to Female Equal Bush ,Bsp Adaptors Connecting Socket Brass Nickel | eBay
IN-LINE Y TYPE STRAINER 15mm Brass Body | eBay
Reply to Pipe coupler issue - connecting two male fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
